BlueRing is a small PCB designed to fit existing Heng Long and Taigen IR receivers/mushrooms to provide visual indication of IR hits. The 4 ultra-bright LEDs on BlueRing flash whenever your battle unit is hit with battle IR shots.
When added to a Heng Long or Taigen mushroom, BlueRing provides all of the functionality of a Tamiya Battle Unit at less than 1/10th of the cost.
Correct functioning of BlueRing requires that your Tank Control MFU provides for indication of IR hits. This is NOT possible with your standard Heng Long or Taigen MFUs. In order to get full IR battle functionality for these units a MAKO2017 is recommended.
BlueRing comes supplied with a 300mm Jst=PH connection cable.
Buy BlueRing Here
