Simple MAKO2020 install for the RX-18 style 27 mHz and 2.4 gHz MFUs
Posted: Tue Oct 01, 2019 12:39 am
by phyrephish
Hi All
If your tank is working 100% and you are happy with it then MAKO install is mind numbingly simple. Here is how..
Re: Simple MAKO2020 install for the RX-18 style 27 mHz and 2.4 gHz MFUs
Posted: Thu Aug 20, 2020 12:19 pm
by Afrikakorps
is this video for the mako2020TK6 ?
The older mako2020 looks more like the mako2018.
For setting up ir and track recoil blocking with the older 2020 model should we follow the 2018 version video guides ?
This would mean relocating the white wire to the additional mako pin as well as to pin 5 (gun /shot motor +power) on the 8 pin section of the heng long 2.4 mfu.
Also replicating the microswitch and of corse using the dual relay board for motor signal interruption.
I hope this is a correct summary of several of your instructional videos.
If I have overlooked anything please let me know.
Thanks
Afrikakorps
by Afrikakorps
Thanks
Afrikakorps
Posted: Thu Aug 20, 2020 12:21 pm
by Afrikakorps
Thanks
Afrikakorps
Posted: Thu Aug 20, 2020 12:25 pm
by Afrikakorps
Thanks
Afrikakorps
