Below are some pics to help MAKO2018 users perform the advanced MAKO install. Installation is the same for ALL versions of Heng Long and Taigen MFUs with the exception of the the last step, the microswitch replicator. Heng Long MFUs use the 4th pin as the microswitch input pin where as Taigen MFUs use the 5th pin. Taigen users should also remember to remove the MFU selection jumper.
I tried this modification using a MAKO2018 and a Henglong 2.4Ghz MFU. It did not work for me. I could not get it to shoot at all. I put it back to the way it was before and it shoots again but only after the BB unit spools up. Is there any other modifications I could try to get rid of the delay in shooting?
