The good old MAKO gets it yearly revamp and 2018 bring some new major changes....
(A) MAKO Input - connect the supplied 5 pin cable here with the other end to the HL/Taigen (Tg) MFU
(B) MAKO Update Port - connect your MANTA programmer here
(C) Legacy IR Output Port - connect your existing HL/Tg battle unit here
(D) Microswitch Simulator - NEW FOR 2018 - connect outer pin to microswitch input on MFU
(E) IR Emitter output - Piranha recommended
(F) Battle Unit Connector - Piranha recommended
(G) Additional Outputs
- G1 - Canon flash or LED
G2 - Recoil servo (NB: Servo with current draw of less than 800mA for direct connection)
G3 - MANTA LCD output
G4 - Track recoil blocking output (separate Relay module required)
(I) Additional Input Pin - for connection to gun motor return and immediate syncing of gun fire.
CONNECTIONS:
Connection to Piranha:
Advanced Connection to Taigen & Heng Long 2.4gHz MFUs:
