It is currently Wed Jul 09, 2025 6:49 am All times are UTC + 10 hours
[ 5 posts ] |
tankdozer
Post subject: motor speeds are different. Posted: Fri Jan 29, 2016 4:15 pm |
Hi Guys. I have a turnigy xr9pro with tankxer9pro I got from RCTA. It all works fine.
I have 2 motors, one on each track. Problem is that because one of my motors is reversed, it runs slower than the other. Can someone please give a a quick heads up how to set the Turnigy to make them run the same speed.
Thanks in advance.
MikeBlandford
Post subject: Re: motor speeds are different. Posted: Fri Feb 26, 2016 10:06 am |
If you haven't solved this yet! Are your motors driven by separate channels? If so, adjust the 'fast' motor channel by reducing the throttle response. Set the weight to less than 100%, say 95%. This will mean the throttle now goes fromm -95% to +95%. Correct this by putting in an offset value of -5% (also set Fix Offset to ON).
Mike.
tankdozer
Post subject: Re: motor speeds are different. Posted: Sun Mar 27, 2016 10:48 am |
Thanks Mike. The motors are on the same channel (I think). That is, I push the 1 lever forward or reverse (channel 2) for either and left or right for power or braked turns (channel 1).
Using mixing of a Dimension Engineering Sabertooth 2 x32 ESC to control the two drive motors. I'm trying to figure out that, since this setup has tank-style mixing as they call it for turns, then it appears logical that one track could be made to revolve and a different RPM than the other. Seems to be a mystery to all. Still trying.
Post subject: Re: motor speeds are different. Posted: Mon Mar 28, 2016 5:15 pm |
Hi tankdozer, sorry I won't be much help for this but I'm a bit confused when you say one motor is reversed and I presume it's not the standard board (like ASP) setup and Tx . I how much slower is it, on my tanks I have a few that one track is a bit slower than the other but it doesn't really worry me. Cheers Gra
Post subject: Re: motor speeds are different. Posted: Tue Mar 29, 2016 11:12 pm |
I have three tanks and all of them have the same problem, one of the motors is a bit faster than the other one. Playing with the trims I can solve it a bit, but really annoys me.
All the tanks should come with gearboxes like the tamiya leopard. Hope somebody makes gearboxes like that for heng long some day...
[ 5 posts ] |
