RC Tanks Australia Forum • View topic - RC5HL Firmware Update
Board index » Electronics » RC5HL
Post new topic Reply to topic  [ 2 posts ]
 Post subject: RC5HL Firmware Update
 Post Posted: Sun Dec 08, 2013 7:29 am
As of today 08 Dec 2013 the RC5HL will be shipped with firmware that allows for gun elevation with both up and down movement on the left stick (Ch3). With prior versions the RC5HL operated in the same way as the RX18 with the cannon triggered with any up stick movement. The new version triggers the cannon with +85% on CH3 only.
However, and this is important to note, the factory wiring of the Heng Long elevation motor DOES NOT ALLOW for the reversal of movement with up and down stick. This is because the elevation motor is wired up to the recoil/bb motors and these motors should not be operated in reverse. FURTHER the Heng Long elevation mechanism is cyclic in operation - eventually one the gun is fully elevated it will then start coming back down. So up stick if held long enough will eventually see the gun lower.
So why make the change?? The new mode of operation brings the operation of the gun elevation more into line with that of all higher end tank control systems (Taipan, EL Mod, SGS, Tamiya,...). It also allows for better integration of our GEKO board to the RC5HL/RX18 combo. With the addition of a GEKO the RC5HL/RX18 system can then provide full proportional control of both turret rotation and gun elevation. GEKO will also circumvent the non reversal issue allowing for the direction of elevation to change with up and down stick.
Although GEKO provides an eloquent solution for enabling better turret and gun control. Some of you may wish to employ your own DIY solutions. It is possible to reverse the elevation motor using a relay which can be triggered using the S1 or S2 functions on the RC5HL. Total cost less than $5 for the relay and some hook up wire plus a bit of your time. More details of how to do this later.
Kevin Grannum
 Post subject: Re: RC5HL Firmware Update
 Post Posted: Sun Dec 08, 2013 7:42 am
silly me :oops: I forgot to mention that any RC5HL owner can easily update their existing RC5HL to the new firmware with the use of a RC5HL programming/update cable and the use of the free DS30 Loader software.
At present the new firmware and Ds30 Loader package will be sent out via email upon request by any RC5HL owner.
If you do not wish to update the firmware yourself you may request a new chip sent to you. A new chip will cost $9 with an additional $3 for worldwide shipping.
