It is currently Tue Jul 08, 2025 11:32 pm All times are UTC + 10 hours
Post subject: Re: TAIPAN Posted: Mon Dec 10, 2012 6:19 pm |
Lookin good Phyrephish Good video The motors run well nice and slow, especially for the big heavy tanks 50 amps I will have to get an all metal tank now Will it have a brake light, and the first production ones will still need the Mako?? As I understand it. Keep up the good work Cheers Gra
Post subject: Re: TAIPAN Posted: Mon Dec 10, 2012 7:28 pm |
Hey Gra At the moment the reverse light comes on with throttle below the mid-point so no it doesn't act like a proper brake light. Maybe a little later down the track but for now actual brake light function is not on the agenda. But there will be: Headlight AUX/Notek Light Convoy light and Reverse light Surely that is enough for now All Taipans will require a MAKO for IR battle function. Guess I'm biased but the MAKO is without a doubt the most flexible IR battle option around. Only the best for the Taipan and the MAKO is the best. Cheers Kevin G
admtiger
Post subject: Re: TAIPAN Posted: Mon Dec 10, 2012 9:22 pm |
Kevin The Taipan is looking really good. I had a less than favourable experience with the Clark TK20 so I am looking forward to the Taipan coming on line.
cheers adam
Darryl Usher
Post subject: Re: TAIPAN Posted: Wed Dec 19, 2012 7:05 am |
I was just thinking, you have different size motor drivers, so do you put the power in to the motor board, then use smaller wire to the rest of the CPU. You could use 12 AWG to 18 AWG to the motor drivers then 22 AWG or 24 AWG for the rest. Darryl Usher
Post subject: Re: TAIPAN Posted: Wed Dec 19, 2012 8:19 am |
Hey Darryl
Your idea is sort of right. Yes the battery will connect to the drive board with it's usual larger gauge wire. So too should you connect the motors with a larger gauge wire. The motor board connects to the control board and it is on the control board that the battery voltage is regulated to 5 v and 3.3 volt supplies. There will be no need for the end user to worry about wire gauge as this will all be taken care of. But as I said you are correct, 12 AWG for the battery supply and motors and the smaller 22 or 24 to everything else.
Cheer Kevin G
971wright
Post subject: Re: TAIPAN Posted: Fri Jan 18, 2013 10:24 pm |
Hi Kevin any more updates ,have been waiting till the Chrismas holidays were over.
regards pete
Post subject: Re: TAIPAN Posted: Sat Jan 19, 2013 8:43 am |
Hey Pete
Most of the work over XMAS has gone into MAKO2 & RC2HL which do inturn feedback into Taipan. Also the new Turnigy 9XR has been released. The 9X or 9XR will be the radios recommended for Taipan. So I have been testing out the 9XR - making a self-centering lever kit for it. Also looking at mounting plates for REMORA or Video screens to attach to the old 9X.
Taipan is different to all existing tank control systems because it provides 2 way communications. So all of the advances made on MAKO2 - REMORA & LCD Diagnostics are Taipan updates.
Also I wanted to do a video of Taipan running inside a tank and realised that I don't have a nice show tank to put it in. Hopefully I can get this sorted and get a vid up soon.
Cheers Keivn G
Post subject: Re: TAIPAN Posted: Tue Apr 02, 2013 7:28 am |
Hi Kevin Any update on the Taipan? i think the Brumbar  would be a good tank for the video cheers gra
Post subject: Re: TAIPAN Posted: Tue Apr 02, 2013 8:58 pm |
Hey Gra
I see I've got a PM from you as well to get on to.... Sorry for the delay. Anyhows below is what has gone off this week for production. It only contains the processing units for the motors. Andrew is working on the sound still.
I guess if you want to use an existing sound module and not planning on IR battle then you could just go with this board and the motor driver board.
Looking at possibly powering the system with a 3 cell battery rather than 2 cell since with 12 volts to play with a significant audio amp could be included.
Jussek
Post subject: Re: TAIPAN Posted: Wed Apr 03, 2013 12:48 am |
hurry up Kevin! i'm about to finish the hull modifications on the PZIV chasis for the wirbelwind! i will start the turret and flakvierling works immediatly, but then i will need the electronic guts to test the flak 'progress' best regards
