Board index » Electronics » Non RCTA Products
Post new topic Reply to topic  [ 12 posts ]  Go to page Previous  1, 2
 Post subject: Re: Turning trim
 Post Posted: Fri Jun 15, 2012 8:06 am
Thanks Kevin
The plug is all the problem but the pin spacing is the same.
This is my second elmod Pro, after the first one died at a tank
show. The first one was fine is all functions.
The second one has all the troubles. You turn on the power,
tank and TX the order makes no difference. You can now turn on
the engine sound. The tank should not move, but it did the tracks
moved at high speed. They sent me a new program that stopped this. Now I have this mixing of steering and throttle problem.
I have decided to send it back.
Darryl
 Post Posted: Tue Aug 07, 2012 10:42 am
I used my Airtronics stylus on 22 and it worked the same as
the 2.4 with my XPS 2.4 conversion. So I sent it back, they
say it works fine. Is anyone using Airtronics 8 ch with Elmod?
I have an old Futaba FG and I will try that when I get the
tank controller back. This radio is before computers, pots for end points.
Darryl
Users browsing this forum: No registered users and 7 guests
