It is currently Sun Jun 29, 2025 10:47 pm All times are UTC + 10 hours
Chad@clark-models
Post subject: Clark-models new rang!!!! Posted: Wed Jun 20, 2012 1:01 pm |
Hi guys, Im the australian rep for clark-models. And id like to inform yous of our high quality made products form 1/35 to 1/16 scale rc tank range. The CSC controller units comes in 4 5 6 or 7 channels to control R/C tank's forward/backward movement, sharp turning, pivoting, turret rotation and gun barrel evaluation at variable speed. Miniature design(30mm X 30mm) for small scale (1/25, 1/35 ,1/48 and etc.) R/C Tank. Auto cutoff protects Li-Polymer battery from over discharged Safety shutoff prevents unwanted movement while signal lost. Status LED indicates Controller operating status. Top and bottom Dual DBF RX connector Mounting hole in center of controller. Auto R/C Control signal detection, support and system. High Resolution Mixer. Tank Personalization Extended Tank Personalization. Status read out and IR battle test via SONY TV remote. Compatible with the heng long tanks! Light & sound module generates engine, cannon and machine gun firing sounds and light according to AFV Status. High quality digital sound. Miniature design( 3cm x 4cm) is suitable for 1/16, 1/25, 1/35 and 1/48 scale tank. Easy to install. Works with Central and Speed Controller. Rotating emergency Light Control 1/35 scale 1/16 scale CHAD CONNOLLY Australian Rep CLARK MODEL http://www.clark-model.comTel : +61 0401742070 Email : Chad@clark-model.com
Chad@clark-models
Post subject: Re: Clark-models new rang!!!! Posted: Mon Jul 02, 2012 10:47 pm |
Just released !!!!! We are proud to announce the release of our latest product the TK-20. A Entry-level & Plug-and-Play Controller for upgrading Heng-Leng RC tank into proportional radio control system with decent sound. Also a great esc for any 1/16 scale tank. TK-20/18 controller uses 4 channels/Heng Leng RC system to control R/C tank's forward/backward movement, sharp turning, pivoting, turret rotation and gun barrel evaluation at variable speed. 20A track motor driver . 22KHz, 8-bit high quality sound with digital sound mixer. Maximum of 5 channel of sound track, main gun, machine gun, turret rotate, gun barrel elevation and engine sound can be generated at the same time with a 3 watt sound output power. Support air-soft gun with sound synchronization. Added support TAMIYA/Heng Leng IR battle format. Safety shutoff prevents unwanted movement while signal lost. Auto R/C Control signal detection, support and 2.4G system. http://www.clark-model.comCHAD CONNOLLY Australian Rep CLARK MODEL http://www.clark-model.comTel : +61 0401742070 Email : Chad@clark-model.com
slowstartgjh
Post subject: Re: Clark-models new rang!!!! Posted: Wed Jul 04, 2012 5:43 am |
Panther Commander |
Post subject: Re: Clark-models new rang!!!! Posted: Fri Jul 06, 2012 6:57 pm |
Hi Chad These units look very good, any chance of a video showing, turret turn, MG and barrel firing. Also do Clark make a recoil unit??? Some prices would be good Cheers Gra
Chad@clark-models
Post subject: Re: Clark-models new rang!!!! Posted: Fri Jul 06, 2012 11:45 pm |
Darryl Usher
Post subject: Re: Clark-models new rang!!!! Posted: Sat Jul 07, 2012 12:54 am |
Size is very good but the control stick layout, page 3 of manual looks wrong. I do not want to use two sticks to get features. A 45 degree movement of one stick will get four features. Moving stick left and right to get cannon up and down seems wrong. Darryl Usher
Chad@clark-models
Post subject: Re: Clark-models new rang!!!! Posted: Sat Jul 07, 2012 6:15 pm |
Post subject: Re: Clark-models new rang!!!! Posted: Sat Jul 07, 2012 7:36 pm |
Hi Chad Thanks for the vid on the mg and cannon sound So it works with the Turnigy TX, which is good cause most of us use the Turnigy. Re the recoil, HL tiger 1 for a start, I'm sure if they are good you will get calls for all the tanks, I'm wanting to upgrade most of my tanks with recoil.
Cheers Gra
Chad@clark-models
Post subject: Re: Clark-models new rang!!!! Posted: Sun Jul 08, 2012 11:36 am |
lol yes the Turnigy units can be flashed with tank software witch removes features that aircraft use making it less complicated to use. I can say now these boards are selling FAST. There is also talk about company selling tanks with our board.
Post subject: Re: Clark-models new rang!!!! Posted: Sun Jul 08, 2012 4:46 pm |
Hey Chad
Left a message on your phone for you to call me. If we can get together maybe I can work out a program for the Turnigy 9X so that the controls are more like what people are used to.
And Gra - really - you and reciol units - like you are searching for the Holy Grail. A $4 HK servo is all you need.
