It is currently Fri Jun 27, 2025 3:14 pm All times are UTC + 10 hours
Spudkopf
Post subject: Re: My StuG Project Posted: Tue Dec 18, 2012 8:39 am |
..... and a little SW animated assembly AVI of the swing-arm attachment proccedure
_________________ SpuD
Spudkopf
Post subject: Re: My StuG Project Posted: Wed Dec 19, 2012 6:26 am |
Tweaked the above animation so it runs slower and in full once uploaded.....
Post subject: Re: My StuG Project Posted: Tue Dec 25, 2012 9:21 am |
Hi Spud Wow good AVI mate, the shocks work well. Have to use more brute force on the rollers, drill a hole in a bit of wood to fit the bracket in so it won't damage the hull And use the "Force" Cheers Gra
Spudkopf
Post subject: Re: My StuG Project Posted: Wed Dec 26, 2012 6:56 pm |
Post subject: Re: My StuG Project Posted: Sun Jul 21, 2013 3:41 pm |
Hey Spudkopf any updates mate...
Spudkopf
Post subject: Re: My StuG Project Posted: Wed Oct 01, 2014 7:53 am |
Spudkopf
Post subject: Re: My StuG Project Posted: Thu Oct 02, 2014 5:55 pm |
Hit a minor snag, some time back I broke part of one of the hinges from the front portion of the loaders hatch, after numerous unsuccessful attempts to make a robust and long term repair, it is now starting to look like the only thing to do is replace it.
Does anybody know where I can get either a replacement HL loaders hatch hinge (or even better still an entire loaders hatch with hinges) or if there is an aftermarket alternative? I seem to recall that there was a kit that allowed you to convert the hatch to the side opening version found on the last production examples, but have not been able to track this one down.
Spudkopf
Post subject: Re: My StuG Project Posted: Wed Oct 08, 2014 7:15 am |
G'day All
Been working on my StuG project (oft referred to as the money pit) pretty much daily, making some progress although very slow.
After the many failed attempts to fix the broken hinge on the forward, I may have finally come up with a permanent solution. I trimmed down a plastic RC aeroplane hing, which was then glued into a slot cut out of the casement roof, this was then reinforced with some plastic card from the inside, admittedly it looks a tad ugly from the inside but its nothing that will be seen anyway.
Why the money pit, well considering that I picked up the StuG quite cheaply to begin with, I've now forked out many times that original purchase price and there's still more to come.
I did end up getting a Taigen hull and keeping in line with mid/late production theme I have also ordered a 7,5 cm KwK 40L48 from Tank-Modellbau.
I have also been reading through the many excellent StuG related project threads both here and over at Hobby Havoc for inspiration, it it amazing what lengths some will go to to build their StuGs, but then almost universally overlook the one same detail.
The detail in question is the spare link rack on the rear of the casement, or more specifically the retention method.
I have looked over many, many references, to confirm what the actual fittings look like, and was quite surprised to see that a fictional method I had originally planned to use was almost identical to that actually used. The following image is the clearest I've found of the fixings.
Find the original here:
I basically have to rely on evergreen plastic products to fabricate my fixings, but in parallel have also mocked up CAD models, one using the same evergreen components and one based on that of the actual fabricated components (pictures to follow shortly). Now if I had access to a 3D printer, I'd already be finished.
Spudkopf
Post subject: Re: My StuG Project Posted: Wed Oct 08, 2014 2:28 pm |
Print worthy (3D) model of the bracket portion of the fixing:
Post subject: Re: My StuG Project Posted: Sat Oct 11, 2014 12:21 pm |
Good to see you back on the stug Spudkopf Cheers Gra
