It is currently Sun Jul 06, 2025 1:00 am All times are UTC + 10 hours
Post subject: IR sensors. Posted: Tue Feb 28, 2017 2:36 am |
Hi Kevin. I want to make my own hidden IR units and the IR sensors that you are using in your Piranha units seems to be what I need. Could you tell me how big are, and where can I buy them?
My idea is to hide the sensors in the turret vision ports.
Post subject: Re: IR sensors. Posted: Tue Feb 28, 2017 6:48 am |
Hi Rad Yes the ones I use will fit in just about all of the vison ports. Was planning to do that with my latest KV-1 build but in the end decided too much trouble with wiring Two types - This one may be better in the ports as it has a flat face http://au.rs-online.com/web/p/ir-receivers/7733899/This is the regular type http://au.rs-online.com/web/p/ir-receivers/7689360/On a KV-1 they would work quite well as they can sit on the top of the hull but for vision ports in cupolas then you need a circuit board. Cheers KG
Post subject: Re: IR sensors. Posted: Sun Mar 05, 2017 6:42 pm |
Hi. Thanks for the fast reply, it looks like what I need. Just a stupid question, how should I solder it? All the IR receivers I used, had 3 legs, and this ones seems to have 4.
Post subject: Re: IR sensors. Posted: Mon Mar 06, 2017 6:34 am |
Hi Rad
Every electrical component you buy will have a datasheet - find/download it and it will tell you what pins are what. I don't have that particular data sheet on hand but even though there are 4 pads there is in fact only 3. Both outer pads are ground V0. I'm sure it will work if you only solder a wire to one of the outer grounds (you don't need both connected).
You will find that multiple ground pads are quite common on SMD components.
