RC Tanks Australia Forum • View topic - New DX6 with rc5hl
Board index » Electronics » Radio Systems
 Post subject: New DX6 with rc5hl
 Post Posted: Sun Sep 28, 2014 2:24 pm
Hi
First post so yes im A noob.
Was wondering if anyone can help.I been trying to use the rc5hl with a New Spectrum DX6.
I can get most things to work but not for life of me can I find any info on how to set up forward & reverse.
My tank only goes foward.
Im using mode 2 and it has me stumped.Can it be done with a mix or something else.
Please help.
 Post subject: Re: New DX6 with rc5hl
 Post Posted: Tue Sep 30, 2014 7:06 am
HI Tigerpies
Ok I will assume noob status :) First up of all the radios and modes you have chosen the combination least used with the RC5HL. There is a setup thread for the Spektrum here:
See the Setup for MODE 2 operation diagram for channel order. You seem to have got CH5 worked out if you can turn on the tank.
Now my usual on Spektrum radios - these radios are great for flying thingies that don't reverse. Planes don't reverse so everything about the Spektrum radios bears this in mind. Spektrum radios do not have self-centering on the throttle lever. My first guess is that you are starting the tank with the throttle lever at the bottom to avoid any throttle warnings from the radio.
When you start the tank the throttle lever must be at centre so that up stick is forward and down stick is backwards. Because it is not self centering you will have to set the lever manually each time at startup.
If the stick is at the bottom when the RC5HL calibrates it will see the entire stick movement as forwards only.
Good luck
 Post Posted: Tue Sep 30, 2014 8:14 pm
Thanks for the reply.
I was trying to get the left hand stick as throttle as its what im used to flying planes and heli,s.
If i have to use right hand stick its no big deal I guess.
I will have another shot at getting it all going when I get some time off and post my results.
Thanks again for your help.
