It is currently Fri Jun 27, 2025 10:00 am All times are UTC + 10 hours
vanhasen
Post subject: Polish Leopard 2A4 1:16 - scratchbuilt Posted: Wed Aug 29, 2012 5:15 am |
Joined: Mon May 21, 2012 2:39 am Posts: 10 Location: Katowice, PL
Hello everybody, I'd like to share with you a little project I started a few (hmm.. six including R&D phase  ) months ago - scratchbuilt radio controlled Leopard 2A4 in 1:16 scale. The assumptions for my build are as follows: 2mm thick aluminium body with resin details, polish markings elmod control module with Turnigy 9x stabilised gun fully regulated suspension, relatively high water resistance very high mud resistance  camera I guess I won't be able to meet all these targets, but even 80% will be good enough for a RC rookie. This is my first RC model (before I was building paper tanks...) so I had to start with basics - learn how this all electronic stuff work. Second step was a CAD project which allowed me to cut most of aluminium parts on waterjet machine. This way I created the set of parts which was glued together with epoxy glue. On the photos below you can see the current status of my Leo. Feel free to any questions.
Post subject: Re: Polish Leopard 2A4 1:16 - scratchbuilt Posted: Thu Aug 30, 2012 5:37 am |
If this is the basic work of a Rookie I would love to see the work of an Expert. It looks better than the Tamiya Kit, Well done. Looking forward to more photo's and video's Cheers Graham
vanhasen
Post subject: Re: Polish Leopard 2A4 1:16 - scratchbuilt Posted: Thu Sep 06, 2012 6:19 am |
Hi, A little update - I made a test and checked the suspension setup. It doesn't look bad. Some fine-tuning should fix the level after final assembly. In the meanwhile I also flashed Turnigy 9x. Thank you
Post subject: Re: Polish Leopard 2A4 1:16 - scratchbuilt Posted: Tue Sep 11, 2012 9:28 am |
great stuff vanhasen you should be able to market those hulls cheers gra
vanhasen
Post subject: Re: Polish Leopard 2A4 1:16 - scratchbuilt Posted: Mon Sep 17, 2012 5:51 pm |
Hi, This week I was able to run the first fileld tests. Below a short (and poor quality...sory) clip showing the performance of the chasis: I also wanted to check the strenght of the motors, but since I had no proper hill for this kind of test I had to borrow one of my wife's tools  My model's weight at this point is about 6kg.
vanhasen
Post subject: Re: Polish Leopard 2A4 1:16 - scratchbuilt Posted: Sun Jan 20, 2013 7:13 am |
Hello everybody, After a long pause I'm back - in fact I got back from a 3-month business trip before the Christmas, but well - there was nothing to report after such a long absence  Now I can show you what I was able do build despite the multidude of other task waiting for me at home. I added some details to the turret and painted (primed) it to check if everything goes fine. Of course it doesn't - so I'll have to fix a few fake welds  My travel was for me also an opportunity to "upgreade" this project a little. There are several items in my drawer which will for sure make it more interesting - FPV equipment and automatic pilot (Ardupilot)  If I'm lucky (and smart) enough I'll have a real HUD...
vanhasen
Post subject: Re: Polish Leopard 2A4 1:16 - scratchbuilt Posted: Wed May 08, 2013 2:25 am |
Small test of turret rotation mechanism: https://www.youtube.com/watch?v=NZjta-_pIaEIt seems like my little trick works - barrel do not hit the rear deck  I also managed to install FPV with some extras, here is the result: And this is how the turret interior looks like at the moment:
B.A.D.A.S.S.Force
Post subject: Re: Polish Leopard 2A4 1:16 - scratchbuilt Posted: Wed May 08, 2013 2:48 am |
Though I'm into the old WWII tanks myself, & I actually don't care for modern tanks much at all, I can't help but admire your extremely fine craftsmanship on this tank ... the results of all your hard work & talent has created a real beauty, something to make one proud indeed!!! Thanks for sharing.
~ Craig ~
vanhasen
Post subject: Re: Polish Leopard 2A4 1:16 - scratchbuilt Posted: Sat Sep 06, 2014 4:18 pm |
Hi, It has been long time since I last did any progress here  The project is frozen - generally due to insufficient power of motors which I used and inadequate workshop to replace them with a proper brushless pair (and resulting motivation crysis, which I had to overcome). Brushed motors with the gear ratio I used are capable to easly achieve correct ahead/reverse speed, but one is unable to make the 8kg model turn  Turning radius in rough terrain is like 2 meters  Meanwhile I decided to fix the core probem so instead of struggling to "revive" this model I was working to improve my workshop - I found some free space, learned a lot, built my own cnc mill, bouht lathe and some other "hardware junk". I also tested it all building another, easier tank - T-34 - http://rctank.pl/forum/viewtopic.php?f=62&t=818But Leopard still has "frozen" status. I intend to continue the idea, just with a different approach  Now I have easly available Heng Long Plastic parts. I want to use the plastic hull and metal upgrade parts (wheels etc.), but scratchbuild the whole interior - replace the gears, create the watertight compartment for electronics etc. The rest of assumptions (FPV, stabilisation) remain the same  Recently I made a set of inserts strenghtening the plastic hull for one of colleagues. Next step - should not be so difficult
Kevin
Post subject: Re: Polish Leopard 2A4 1:16 - scratchbuilt Posted: Sat Sep 06, 2014 4:22 pm |
Hi, great idea vanbasten!
