It is currently Thu Jun 26, 2025 2:28 am All times are UTC + 10 hours
Post subject: Gra's HL Tiger 1 Posted: Wed Oct 17, 2012 7:28 am |
Hi all been going to post this for ages, my first tank mod started back in 2007 ( and still going LOL) main mods i have done metal tracks, 3/1 gearboxes, El Mod Eco with IR, Taigen recoil unit and metal barrel scratch built smoke dischargers with cables and shrapnel grenade launchers, turret track hangers, fire extinguisher, front grab handle, light wires and also closed the opened pin tracks up on the turret and front track holder. have modified the HL suspension and added some extra screws to the turret ring. some pics (these are early pics with the plastic tracks first) more to come gra
Post subject: Re: Gra's HL Tiger 1 Posted: Wed Oct 17, 2012 7:33 am |
more pics
Post subject: Re: Gra's HL Tiger 1 Posted: Wed Oct 17, 2012 7:39 am |
more pics
Post subject: Re: Gra's HL Tiger 1 Posted: Wed Oct 17, 2012 7:50 am |
suspension mod....this is an easy solution to lower the wheel axels of the HL Tiger 1 suspension (including Pantiger and Matorro tanks) i used a dremmel and ground out the bottom of the axel groove in the side of the hull and extended t by about 3.5mm these pics shows the HL suspension as is next pics shows modded axel holes bit hard to see but the axels are lower now it certainly makes a difference cheers gra
Post subject: Re: Gra's HL Tiger 1 Posted: Wed Oct 17, 2012 7:57 am |
idler wheel bearing mod.... I drilled out the hub a bit with 10mm drill and fitted 2 x 10mm bearings, since have used the 5mm braces from the HL gearboxes, they run nice and straight put some screws in to hold the idler together, bit of paint covers it all up
Post subject: Re: Gra's HL Tiger 1 Posted: Wed Oct 17, 2012 8:10 am |
another mod, added extra screw to the turret ring to strengthen it up and take out some of the wobble has 4 screws instead of 3 now also made the ring turn 360 deg installed a Taigen (was Asiatam) recoil unit, bit of a fiddley job (the mantlet comes with the kit) i bought the Mato BB barrel first, before i realised it was the bb version then bought the Taigen recoil version barrel with the brass muzzle brake put a small sleeve in the mantlet to keep the barrel centered i had raise the mantlet up as it was sitting to low on the turret and cut a new hole for the elevation arm then had to fine trim the recoil unit lever so when you fired the gun it would recoil straight away, as was it moved around for a few seconds before it would release the barrel cheers gra
Post subject: Re: Gra's HL Tiger 1 Posted: Sun Oct 21, 2012 2:26 am |
Some great looking work there Gra. I'm considering going back to do some more work with my Tiger. So watching your build is definately making me want to get on and do it. Ian.
The Hag
Post subject: Re: Gra's HL Tiger 1 Posted: Wed Jan 09, 2013 9:17 pm |
Joined: Tue Jan 08, 2013 7:22 pm Posts: 9 Location: Gold coast
Looks really good, was there no zimerrit on this tank?
ranman38
Post subject: Re: Gra's HL Tiger 1 Posted: Sat Jan 12, 2013 1:25 am |
Most early tigers with feifel still attached would not have zimmerit
ranman38
Post subject: Re: Gra's HL Tiger 1 Posted: Sat Jan 12, 2013 1:27 am |
Nice mods, I may have to adopt a few of them. My asiatam recoil has been problematic from the get go. It seems to get jammed, and now as I said in another post it will not work at all. Disappointed in it. May have to disassemble it and lube it up and have another go.
