It is currently Tue Jul 01, 2025 8:58 am All times are UTC + 10 hours
reyemmanuel
Post subject: Charging RCTA's Turnigy 2650mAh Transmitter Pack Posted: Fri Feb 07, 2014 10:55 am |
Willys MB Driver |
Joined: Thu Sep 01, 2011 12:59 am Posts: 21 Location: Newcastle, NSW
Hi Kev,
Was wondering how'd you charge RCTA's Turnigy 2650mAh Transmitter Pack. My pack only has the JST balance lead and JST lead (main) for the Radio.
Is there a way to charge this without having to add-on an adapter to the main lead for charging with the Accucel (got this from RCTA also)?
Can I charge using the balance lead only? Thanks.
cheers,Rey
Post subject: Re: Charging RCTA's Turnigy 2650mAh Transmitter Pack Posted: Sat Feb 08, 2014 7:32 pm |
HI Rey You will need an adapter. I don't think any of the adapters with the metal Accucel will work.
Of course you could try to charge in the radio - the main pair of leads to the battery in via the charging jack on the radio then the balance plug into the port on the Accucel.
reyemmanuel
Post subject: Re: Charging RCTA's Turnigy 2650mAh Transmitter Pack Posted: Sun Feb 09, 2014 10:56 pm |
Willys MB Driver |
thanks Kev,
Yah, i reckon will do make an adapter and charge outside the radio.
cheers,Rey
