RC Tanks Australia Forum • View topic - Frosty's HL Jagdpanther Mod
Board index » German Panzers » Panther and Variants » 1/16 Scale Builds
Post new topic Reply to topic  [ 5 posts ]
 Post subject: Re: Frosty's HL Jagdpanther Mod
 Post Posted: Wed Apr 25, 2012 12:11 pm
Great work Diverfrost
The styrene certainly makes a difference
Like the welds and jack block straps 8-) 8-)
Couple of hints and tips for you :)
The jack block holder
When I join styrene I drill a hole and insert a styrene rod into the join, usually 1.5 mm to 2mm depending on the piece
It just makes a stronger join, if attaching a piece to the side of the tank eg track holders use rod to insert into the tank plastic again it makes a stronger join especially when on the side of tanks where things can get hit, and can you can also leave a bit of rod sticking out and it looks like a bolt head (can see pics of track holders on my Pantiger mod on old havoc)
Same with hinges etc, can insert rod into the bolt holes, leave a bit out for the bolt head and again makes a stronger hold
Cause some things don't stick tothe HL plastic that well
Hope this helps
Hope the next pics arrive soon ;)
Gra :)
Gra's Heavy Tank Regiment
Panzergruppe South Member
 Post Posted: Fri Apr 27, 2012 8:31 am
I'm buying shares in Evergreen, now that you and Gra are up and modding tanks. :D
I still can't bend the stuff properly. Good work, Frosty.
 Post Posted: Sun Apr 29, 2012 9:26 am
 Post Posted: Wed Jun 06, 2012 12:12 pm
This is going to be one nice tank.....great work. Wheels look excellent
 Post Posted: Mon Mar 04, 2013 12:56 am
Pz III Commander
Pz III Commander
awesome jagdpanther :D do you have the final photos of the result? And did you customize the electro inside or is it al default?
Garage:
Users browsing this forum: No registered users and 1 guest
