It is currently Mon Jun 30, 2025 6:37 am All times are UTC + 10 hours
Post subject: Got Smoke? Posted: Sun Aug 02, 2015 7:59 pm |
One thing missing from Asp was prop control of a smoke unit. This was left off and only basic control implemented as the stock smoke units are noisy and not quite up to the task in my opinion. I've been waiting for a good smoke solution and I think the new Burn Effect Smoke Generator is on the way there. Unfortunately, the stock control board supplied won't really do the job (after all it is meant for drift cars) so after a bit of tweaking of a Sirvoe board and the program running on Asp I think I've got a smoke solution that I would like to put into one of my tanks. Check out the results below. Remember the engine rev sound is just that a rev of the engine in neutral. So you could just sit there revving your tank engine and looking like some Tanker Hoon  Enjoy Cheers KG
Post subject: Re: Got Smoke? Posted: Sun Aug 02, 2015 9:12 pm |
Now that's what I call a smoke machine Looks great Kevin. What's the smoke coming out of the top of the unit for? Can that be stopped or piped back into the exhaust as well? Is that the A7 sound set if so I luv it Cheers Gra
Extra text |
Post subject: Re: Got Smoke? Posted: Mon Aug 03, 2015 9:09 am |
Hi Graham
Although there is no mention of the hole in the instruction sheet clearly it is a vent for the over pressurization of the fluid chamber. The design above is one I did in 2 minutes for the video only. As you can see below the output is severely restricted by my use of much thinner tubing and the length of the tubing.
That smoke still comes out of the exhaust is wonder in itself. Yes, you could plug the hole, Yes, you could re route the vent output. However, best solution would be to use wider bore tubing and minimise distance between unit and exhaust out.
Thor91172
Post subject: Re: Got Smoke? Posted: Wed Aug 05, 2015 11:35 pm |
Kevin,
What JST port did you use for the servoe?
Thanks, John
Post subject: Re: Got Smoke? Posted: Thu Aug 06, 2015 7:11 am |
HI John There is no port  Since this has come out after I designed Asp you need to make a mod. You get the control signal from where the white wire on your programmer plugs in for updates of the LED controller IC. You can then take the 5V+ and V0 from nearby pads. I will make a video and a page with details soon. That is pretty much the only spare processor pin left available on the main board. An actual port for this won't exist until a redesign of the board (ASP Mk2). Which won't be happening in the next 12 months. Cheers KG
Matthewnimmo
Post subject: Re: Got Smoke? Posted: Wed Dec 23, 2015 12:10 pm |
Hello:
This is my official post on this forum. Ive recently purchased an ASP and im anxiously awaiting for it to arrive. I also purchased a sirvoe board. Ultimately i wanted the asp so that i can use my hobbie remote on my new taigen tiger and not the crappy transmitter supplied. But, as i continued to watxh more footage on the asp board i found this amazing video of asp + sirvoe board + burn effect v3 unit producing some amazing smoke effects
So, with all that said im looking for some instruction on what to do to make this happen when my asp and sirvoe board areives. Where do i start, what do i need to mod if anything? Any help would be tremendously appreciated
Thanks again,
Post subject: Re: Got Smoke? Posted: Wed Dec 23, 2015 10:53 pm |
Matthewnimmo
Post subject: Re: Got Smoke? Posted: Thu Dec 24, 2015 1:59 am |
Sounds like a plan with the manta board. If you have a paypal account ill send you the payment today. As i have hobbie grade tx and rx so sounds like i can do this myself:). Id send you a private message but I believe the forum board sees me as too new still (which I understand)
Post subject: Re: Got Smoke? Posted: Thu Dec 24, 2015 10:06 am |
shouldn't now as you have posted 3 messages
Matthewnimmo
Post subject: Re: Got Smoke? Posted: Thu Dec 24, 2015 1:08 pm |
