Soundmodul USM-HL - BEIER-Electronic http://rctanksaustralia.com/forum/viewtopic.php?f=153&t=76 |
Author: | Admin [ Sun Jun 05, 2011 8:37 pm ] |
Post subject: | Soundmodul USM-HL - BEIER-Electronic |
Soundmodul USM-HL - BEIER-Electronic Website: http://www.beier-electronic.de/modellbau/index.php Cost: 129.00€ with CD-ROM, Data Cable & Manual; 119.00€ without accessories ---- Google Translation ---- The sound module USM-HL is designed for the tanks of the manufacturer "Heng Long" adjusted, the RX-18 have added a control. With the USM-HL, the tanks, with a most faithful, speed dependent engine sound are provided. To Background noise to make it perfect, in addition to the engine sound, yet to play up to 12 additional sounds. Automatic starting, stopping, starting, Anhalt, stall, stop, reverse and can also Kettenquietschgeräusche be played. Furthermore, even 8 comfortably configurable Random sounds. The sound playback is four channels in this module, ie it can in addition to the moving vehicle for up to 3 other Zusatz-/Zufallssounds play simultaneously. The information of the driving speed is, with this sound module from the HL-existing receiver tapped. All other sounds can be so be triggered directly through the station without complicated wiring necessary. All sounds can be changed any time on the sound module. These are only A Windows PC with USB interface and our software "Sound USM-HL- Teacher needed. You can use this sound module so for a variety of Models use. Since even a powerful audio amplifier is on the board, need for sound output only speakers. For this purpose, the original, built-in speakers are used. At 7 switching outputs such as LEDs or lamps, relays connected be, that one variety of lighting effects (eg light, reverse light, Brake lights, hazard lights, machine gun fire, cannon fire, flickering light, etc.) can be realized. ---- End Google ---- |
Author: | Gra [ Sun Jun 19, 2011 5:18 pm ] |
Post subject: | Re: Soundmodul USM-HL - BEIER-Electronic |
This looks good ![]() Is the engine sound proportional?? cheers gra |
