It is currently Wed Jul 02, 2025 2:17 am All times are UTC + 10 hours
TeckPriezt
Post subject: RC2HL Setup Problem Posted: Tue Dec 10, 2013 5:13 pm |
Just setup my Turnigy 9X and RC2HL after having it sitting on the shelf for a while.
I have installed the tankER9X (Bastille) firmware on my 9X and setup up as per the great setup vids on YouTube. But getting a strange problem.
The move barrel left and right and tank movement left and right works perfectly, but the move forward and backwards as well as the fire and move barrel up and down functions do not work.
Anyone have any ideas on why this would be happening?
Post subject: Re: RC2HL Setup Problem Posted: Wed Dec 11, 2013 7:48 am |
to me it sounds like the channels need reversing. most radios have a switch for each channel to reverse, but i'm not certain with the Turnigy 9X if it's all done via switches or through the software.
Post subject: Re: RC2HL Setup Problem Posted: Wed Dec 11, 2013 12:01 pm |
Hi TP One of the beauties of ER9X is that you can download your radio setting and post them so that we can all see what is going on.
Connect your radio to your PC and using eePe
Click BURN - Read Memory From TX
Once done save the file as TeckPriezt.eepe and then post it here (you may have to zip it up first).
Also it really helps to send as much info as you can - like are you using 6 or 8 channel receiver???
Quickly looking at your issue when you setup the template did you FIRST
Make sure that in Radio setup MODE 3 was selected
The when you went to templates did you FIRST change channel order from RETA (default) to RTEA - first thing I though of give that R (steering) and A (turret right left) are working fine since they are in the same place and you have issues with T and E.
THEN did you CLEAR ALL MIXES - before applying the RC2HL template.
Finally the templates apply everything EXCEPT the reverse settings- You need to manually reverse CH1, CH2 and CH3
Go to LIMITS page all the way to end of line and change - - - to INV by pressing MENU
Good Luck KG
