RC5HL and Turnigy 9XR Video Manual Series http://rctanksaustralia.com/forum/viewtopic.php?f=148&t=761 |
Author: | Admin [ Sun Sep 08, 2013 7:52 am ] |
Post subject: | RC5HL and Turnigy 9XR Video Manual Series |
As owners of the Turnigy 9X radio would know there is no printed user manual. Further any such manual would be useless anyway with installation of custom firmware such as tankER9X. Being a simple variant of ER9X users should revert to the online material for ER9X for reference. The first and best place to start is: https://code.google.com/p/er9x/ From there you will find links to all necessary 'bits and pieces'. This post will focus on the RCXHL and 9X/9XR radio combination to serve as a reference and trouble shooting video guide. The post will be locked. If you have a problem and want to ask a question please start a separate topic to that your issue may be specifically addressed. Thanks. Now on with the show... 9XR Module Selection - Choosing what radio module for your 9XR A brief look at Turnigy compatible, Spektrum compatible or FrSky radio modules for the 9XR. All of the modules shown are used for testing RC Tanks Australia boards and products. 9XR and 9X - Accessory mounts and USB connection Available accessories for the 9XR and 9X radios and location of the ISP interface. 9XR & RC5HL Setup - Correct cable connection and jumper selection for the RC5HL How to connect the 6 channel HobbyKing and 8 channel Turnigy receivers to the RC5HL. Please note that for the 8 channel receiver CH2 goes into IN3 and CH3 into IN2. Also note the positions for the receiver selection jumper. 9XR Binding Procedure How to bind your Turnigy compatible receiver to your 9X/9XR radio while connected to the RCXHL 9XR & RC5HL Startup - Correct Operational Response of the 9X/9XR This video shows how the 9X/9XR radio should respond for correct operation of your RC5HL 9XR & RC5HL - Basic Trouble Shooting This video shows how to reset your RC5HL equipped model should you inadvertently change the MIXER settings. 9XR & RC2HL Setup - Template Application This video shows the extra steps required to apply the RC2HL template for the 9X and 9XR radios. Templates are unable to apply reverse settings for channels and hence you must manually reverse CH1, CH2 and CH3 for proper operation of the RC2HL board. Channel reverse is done on the LIMITS page. 9XR Correct Mode Selection For the 9XR to function in a similar manner to the Heng Long Controller it is necessary to make sure that the correct stick mode is selected. This mode is Mode 3. This video will show you how to setup Mode 3. |
