It is currently Sun Jul 06, 2025 10:58 pm All times are UTC + 10 hours
[ 5 posts ] |
scoopey
Post subject: Mako 2- Muzzle flash query Posted: Tue Jun 04, 2013 7:06 pm |
Originally with Heng Long electrics and TX you had to use a diode to force a trigger for the flash and IR to work. With the RC2HL installed and operating via switch on the Turnigy 9x does this "trigger" diode need to be used?
Post subject: Re: Mako 2- Muzzle flash query Posted: Wed Jun 05, 2013 1:54 am |
No you don’t need the diode mod. When you push up with the left thumb stick that has same action as pushing the K button on the HL controller transmitter, so fires IR, activates the flash, get the sound and track recoil (if no ATRC fitted)
scoopey
Post subject: Re: Mako 2- Muzzle flash query Posted: Wed Jun 05, 2013 6:41 am |
Thanks, that will simplify the wiring!
scoopey
Post subject: Re: Mako 2- Muzzle flash query Posted: Wed Jun 05, 2013 8:16 pm |
I gather this means when using a servo recoil with an RC2HL and Mako the 2 pin (from the 5 + 2) trigger does not do anything
Post subject: Re: Mako 2- Muzzle flash query Posted: Wed Jun 05, 2013 10:01 pm |
Yes the 2 pin isn't required its not even installed on my tank.
Ian
[ 5 posts ] |
