It is currently Mon Jul 07, 2025 4:59 am All times are UTC + 10 hours
[ 5 posts ] |
tisaksen
Post subject: Override RX18 turning? Posted: Thu Nov 08, 2012 7:11 am |
Is it possible to use tankER9x to override how the tank turns? Right now its one belt forward and the other one backwards. I wish I could controll this and ideally the speed of each motor but I guess I'll need a separate ESC for each motor?
Post subject: Re: Override RX18 turning? Posted: Thu Nov 08, 2012 7:30 am |
I think that it should be possible (pretty sure actually) - see ZAK's post on how to disable superspin.
Sorry I don't have the link but it is somewhere here on the forum
tisaksen
Post subject: Re: Override RX18 turning? Posted: Thu Nov 08, 2012 4:38 pm |
Oh right, I remember that one, I never got around to testing that setup.
zak
Post subject: Re: Override RX18 turning? Posted: Thu Nov 08, 2012 5:54 pm |
I works ok; kills pivot turns but also kills proportional turns; ie it won't run one track at 100% and the other at 90%, it only turns by stopping the left or the right completely, or pivot with switch.
tisaksen
Post subject: Re: Override RX18 turning? Posted: Thu Nov 08, 2012 6:32 pm |
My tank uses one track only when turning at low speed, the other track does not move at all, but what I want to get rid of is the fact that it will make one track go forward and the other backwards when I turn with a little more throttle.. I have no idea why it's doing that. I simply want to slow down one track when turning, not reverse it.
[ 5 posts ] |
