RC Tanks Australia Forum :: View topic - Turnigy 9x Important Things To Know
http://rctanksaustralia.com/forum/viewtopic.php?f=117&t=127
Author:  Admin [ Sat Aug 13, 2011 11:15 pm ]
Post subject:  Turnigy 9x Important Things To Know
For the money the Turnigy 9X is pretty damn cool. So if you are thinking of getting one or have just got one here are some important things to know.
1. The cover for the battery compartment is a bee-atch to fit. (if you are using the included 8 x AA battery pack)
2. If you turn it on for the first time and it just beeps at you don't worry it is not broken. It is a safety feature to make sure all the switches are in a 'safe position' for model startup. Simply make sure all the switches on the back are down and those on the front are up.
3. It may not work as a simulator for your flight sims programs such as FSM with out a bit of modification.
4. You can replace the AA battery pack with a Lipo battery. However, if you do this you must monitor your battery voltage manually. The usual LiPo fitted is the Zippy Flightmax 2500 mAh LiPo available from the
more to follow...
