It is currently Wed Jul 09, 2025 10:04 pm All times are UTC + 10 hours
[ 2 posts ] |
Post subject: 9XR Pro Programming Help Posted: Sat Nov 07, 2015 8:34 pm |
Hi Guys,
I've a 9XR Pro with standard firmware which I'm using for a RC excavator, but I'm a bit stuck on something.
At the moment I have a brushless ESC connected to channel 5 which is assigned a rotatory knob, channels 6, 7, 8 have servos attached to the hydraulic valve block to control the pistons. channels 6,7, 8 are programmed on the thumb sticks.
So currently I turn the knob about 1/4 turn to get about 25% throttle on the pump ESC then I can play around with the thumb sticks to get the pistons moving.
But I want to try this setup.
When ever I move thumb sticks (channels 6,7, 8) the pump automatically start at 25%
I tried adding mixing to channel 5 but it doesn't work for when I move a stick left or down only right or up plus it appears to take the sum of all 3 sticks so can get 75% in some stick configurations.
I'm sure I'm missing the obvious but any suggestions welcome.
Post subject: Re: 9XR Pro Programming Help Posted: Mon Nov 09, 2015 6:12 am |
Hi guys,
Figured it out, guy on another forum sent me a eepe file to view and figured out I need to add a curve profile to the command lines.
[ 2 posts ] |
