It is currently Mon Jul 07, 2025 10:32 am All times are UTC + 10 hours
Post subject: Re: Adding a 6-position switch to your Turnigy 9X or 9XR Pro Posted: Thu Sep 01, 2016 10:40 am |
ok, thanks, so switch dependent, got it.
ArchOlson
Post subject: Re: Adding a 6-position switch to your Turnigy 9X or 9XR Pro Posted: Tue Sep 27, 2016 4:02 am |
Hi..in my case if a voice message was playing, beeps were lost. I now merge the beeps with the voice message. In addition, I've added a 'background audio' option. With this you may play an audio file, which will have beeps merged with it, and will be paused while any voice message is played. You may even create 'play lists' of several audio files to be played one after another and set a 'loop' option to repeat the list.
Post subject: Re: Adding a 6-position switch to your Turnigy 9X or 9XR Pro Posted: Fri Jun 09, 2017 2:53 pm |
I figured this out long time ago, just forgot to update, and coincidentally now came across it so here it is in case anyone needs it. The below is a curve that works for Taranis in openTX for setting up 6pos switch: curve.PNG
